Just bought a 97 XJ6 and worked out that a fuse had blown because the rear right light wasn't coming on when the lights were turned on, but when I open the trunk the 2 trunk lights are on as I open the trunk but they go off when I lift the trunk more than about 10 inches. Also the licence plate light on the same side is out, I have changed the bulb and the only response I can get is when I touch a screw driver to one side of the bulb and to the car body, the light comes on, like it is not earthed properly......I just thought the trunk lights and the licence plate may be connected. Your help is greatly appreciated. Thank you.
Sep 13, 2008 at 2:36 PM
