1997 Jaguar XJ6 Indicators,wipers,main beam,hazards dont wo
1997 JAGUAR XJ6
WILLIAM MCCRAE
Electrical problem
1997 Jaguar XJ6 6 cyl Two Wheel Drive Automatic
why wont my hazards main beam, and wipers work?
Feb 26, 2010 at 4:24 AM
DAVE H
  • 13,384 POSTS
check/replace the combinsation switch
COMBINATION SWITCH
Removal & Installation
Disconnect battery ground lead. Extend steering column fully and lock. Remove steering wheel. See STEERING WHEEL & HORN PAD . Remove rheostat switch knob and screws securing column lower cover. Remove lower cover and upper cover screws. Remove upper cover.
Remove screws securing left hand connector mounting plate. Reposition plate to access flasher switch harness connector, and disconnect connector. Remove switch securing bolt and remove switch. To install, reverse removal procedure.
Feb 28, 2010 at 10:56 AM
