1993 Jaguar XJ6 Noisy vibrations.
1993 JAGUAR XJ6
11,300 MILES • 6 CYL • 2WD • AUTOMATIC
MONYMAN
My 1993 xj6 makes a rumbling noise between the speeds of 35mph and 55mph. It also seems that something is loose near the passenger side rear wheel. It goes away after it reaches approximately 60 mph. what could this possible be? The tires are balanced and there is nothing that I can find. My concern is that this could be a costly situation. I need some advice before I take it to a dealer to repair.
Jan 4, 2008 at 3:35 AM
JAMES W.
  • 2,394 POSTS
Sounds like a drive axle u-joint. It should "klunk" when you shift from drive to reverse and back.
It could be an wheel bearing but, they usually get louder the faster you go. Note: these u-joints are usually lubeable but, a lot of "oil change" places don't.
Oct 8, 2008 at 6:26 AM
