1991 Jaguar XJ6
LSIX1
  • 1991 JAGUAR XJ6
1991 Jaguar XJ6
How do you remove the old key Barrel fom the steering column to install a new one?
Friday, April 10th, 2009 AT 1:22 PM
DAVE H
  • 13,384 POSTS
IGNITION SWITCH & LOCK CYLINDER
Removal
Disconnect battery ground. Remove steering wheel. See STEERING WHEEL & HORN PAD. Remove steering wheel spline adapter ring. Remove instrument illumination rheostat control knob. Remove lower and then upper cover. Remove column switch-gear mounting bracket-to-upper column securing bolts. Reposition mounting bracket and remove upper nacelle. Reposition switch-gear mounting bracket to all access to ignition switch.
Disconnect ignition switch harness multi-plug. Release ignition switch harness multi-plug. Release ignition switch retaining tags. Remove ignition switch from lock assembly. Using a suitable punch, remove shear bolts securing lock assembly. Release switch assembly.
Installation
For installation, reverse removal procedure, using new shear bolts
Sunday, October 25th, 2009 AT 6:33 AM
