1986 Jaguar XJ6 stalls
VBRAGG
  • 19 POSTS
Sorry 13 ohms
Thursday, May 7th, 2009 AT 7:16 AM
You go 13ohms that means the wire is not open and you're not getting power both side of the inertia switch. Replace the ignition switch.
Thursday, May 7th, 2009 AT 3:25 PM
VBRAGG
  • 19 POSTS
I'll have to order the switch. I'll let you know how I make out.
Many Thanks, Vern
Friday, May 8th, 2009 AT 5:28 AM
VBRAGG
  • 19 POSTS
It took over a week to get an ignition switch. I just put it in and nothing. No change. Will only run for a few seconds and then stall. Fuel pump is not coming on with the ignition switch. Any more ideas?
Thanks, Vern
Saturday, May 16th, 2009 AT 2:50 PM
At the main relay socket check for power at the brown wire
Saturday, May 16th, 2009 AT 4:44 PM
VBRAGG
  • 19 POSTS
Yes, there is power with the key in the on position.
Sunday, May 17th, 2009 AT 5:20 PM
Okay recheck the airflow meter as stated earlier with Dave H
Sunday, May 17th, 2009 AT 6:24 PM
VBRAGG
  • 19 POSTS
I can't remember doing a test on the flow meter. He explained how it worked and that was it. How do I test this unit?
Sunday, May 17th, 2009 AT 8:14 PM
Try blocking the flap open and attempt to start the vehicle
Sunday, May 17th, 2009 AT 11:05 PM
VBRAGG
  • 19 POSTS
I blocked the flap partially open with a screw driver and started the car. Idled perfectly, would accelerate slowly. Bingo, I think we hit a homer. I'll try to find an air flow meter.
Monday, May 18th, 2009 AT 5:18 AM
VBRAGG
  • 19 POSTS
Is it the air flow meter?
Monday, May 18th, 2009 AT 5:23 AM
Yes sir its the air flow meter
Monday, May 18th, 2009 AT 2:34 PM
VBRAGG
  • 19 POSTS
Installed air flow meter and she took right off. The car was not getting any air apparently. This should have been checked before. My grandfather once told me that Lucas almost cost the British the war. It had over half its planes grounded for electrical reasons.
Many Thanks, Vern
Tuesday, May 19th, 2009 AT 12:56 PM
BENTLEY EVERSLEY
  • 31 POSTS
To whom it may concern, check the Mass air flow sensor, it's the silver box between the air filter and the throttle body. Take the black cover off and crank the engine watch the needle, see if the car try to start as the needle moves. Get your wife to try starting the car as you hold the needle open just a little. Let me know what the outcome was. I think you have a bad Mass air flow sensor. Also make sure the inerit swithc for the fuel cut off is in the down position. This is the switch you had throuble finding in the interior. Get back to me and let me know the outcome.
Monday, September 14th, 2009 AT 9:28 PM
