2004 Jaguar X-Type mis-fire and smokey exhaust
BUNNY 63
  • 2004 JAGUAR X-TYPE
  • 6 CYL
  • MANUAL
  • 70,000 MILES
The car is mis-firing a little on acceleration also their is black smoke coming from the exhaust. At the same time I can hear a windy noise from the right hand side of the engine.
Friday, May 7th, 2010 AT 2:32 PM
MERLIN2021
  • 17,250 POSTS
It is most definitely running way too rich, this could by bad O2 sensors or leaky injectors, Jags are famous for the injectors, if you do it do all at the same time, but read the codes and check fuel pressure and do an injector leak down test.
Also:
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on.
If the light is blinking, it means engine misfires possible damage to the Catalytic converter. Service it right away!
Friday, May 7th, 2010 AT 5:40 PM
