I need to know where the low side intake valve is so that I can recharge my A/C system. I can see the upper valve but cannot find the lower valve where I need to attach to add refrigerant.
Tuesday, August 11th, 2009 AT 4:29 PM
WANG DAWEI
MEMBER
The low pressure service gauge port valve is located on the manifold and tube assembly - A/C compressor.
If you want to make access to the low pressure service port, you must lift your car up.
