engine codes
JAGUAR
TNEAL
2001 jaguar s-type 4.0 engine code p1584 &p0065 could you tell me what the problem is and what to replace please thank you
Jun 15, 2007 at 11:57 AM
DAVE H
  • 13,383 POSTS
DTC P0065 (V8 ENGINE): AAI VALVE FAILURE
Diagnostic Trouble Codes Description
Air Assisted Fuel Injection (AAI) control range/performance. This DTC is set by the Engine Management System (EMS). This DTC is an OBD II fault. CHECK ENGINE light is activated after 2 consecutive trips with fault present. Diagnostic information for this DTC is not available.
DTC P1584: THROTTLE BODY FAILURE
Throttle actuation malfunction. This DTC is set by the Engine Management System (EMS). This DTC is an OBD II fault. CHECK ENGINE light is activated after 2 consecutive trips with fault present. Amber malfunction light (left of message center) is illuminated with fault present. A message is displayed on message center. Diagnostic information for this DTC is not available.
Oct 25, 2009 at 2:19 AM
