It sparks but will not start?
15,893 MILES
SIANA_12
We check the brain of car which is good. The coils are good, the fuel pump is good camshaft is good. We change the crank sensor, but the car just would not start.
Nov 30, 2022 at 1:41 AM
  • 110,248 POSTS
If you have an ignition spark, see if it starts for a couple of seconds using starting fluid. and then stalls. If it does, we know it's a fuel-related issue.
If there is no change, recheck the ignition spark.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
If you do have a good spark at the plugs and the starting fluid makes no difference, I need you to record it cranking and upload it for me to hear.
Also, I need to know which engine this has. Is it the 2.5L or the 3.5L?
Let me know what you find or if you have questions.
Nov 30, 2022 at 1:22 PM
