2001 Isuzu Trooper Please Help!! 2001 Isuzu Trooper Transmi
2001 ISUZU TROOPER
90,000 MILES • 4 CYL • 4WD • AUTOMATIC
LEFTYKNOX
Quick story: My wife was driving our Isuzu Trooper and rear-ended someone. $3500 damage to our car - radiator was damaged but transmission seemed fine. Took it to the repair place and they fixed the bumper, radiator, etc. I drove it away and could immediately hear a "whine" in the engine but thought it was just from new parts or something. Within 24 hours, the car wasn't drivable. Took it back to the repair shop and they told me my transmission was shot but that it didn't have anything to do with the accident and showed me pictures of all of the burnt up fluid that came out of it. Repair place is telling me that I'm going to have to pay up to get it fixed because it wasn't their fault. My insurance is saying they won't pay for it because it wasn't part of the accident.
Keep in mind though that I have never had any transmission problems with that car including and up until the day of the car accident. Not only that, but I have a receipt showing that I had the transmission fluid checked (and the lube shop confirmed that they check quality and color of the fluid) just two weeks before the accident.
How possible is it that the repair place accidentally allowed too much transmission fluid to leak out when they were repairing the radiator and consequently burnt up the engine (they tell me only an 1/8 of a cup of fluid would have leaked out) but are now showing these pictures that came from who-knows-where so they can back up that there was plenty of transmission fluid in it and it wasn't their fault?
Also, is it possible that when the accident happened, the transmission was jarred and corrosion came loose and mixed in with the fluid to cause it to be in such bad shape?
Any ideas on what happened here? Part of the problem too is that I don't exactly remember when I last had my transmission flushed and I don't have a receipt on it. Any help you can give is much appreciated. Thanks.
May 21, 2009 at 5:35 AM
2CARPRO JACK
  • 11,533 POSTS
I would look to see if the cooler lines were pinched or restricted somehow from the accident.Overheating can kill an auto trans in no time flat.See if the shop repaired the lines, if so that coupled with the receipt from the other shop from the previous 2 weeks should be enough for you to do battle with the insurance company/repair shop over
May 22, 2009 at 12:49 AM
LEFTYKNOX
Thanks for the response. I guess part of the issue seems to be that checking the transmission fluid in a Trooper is pretty difficult as it's a "sealed unit." Is that right? So I'm afraid that my earlier "check-up" might have skipped that part out of convenience but still marked that the fluid had been checked.
Also, is it possible that corrosion can get knocked loose in the transmission during an accident and can cause the poor quality of transmission fluid? Thanks again.
May 22, 2009 at 2:09 AM
2CARPRO JACK
  • 11,533 POSTS
Possible but no tlikely.If thematerial gets knocked loose,it will not make the fluid smell burnt or be enough to discolor the fluid, they hold about 12 quarts.Yes it is a pain to check the fluid, that is why many get skipped and not serviced
May 22, 2009 at 4:58 AM
