Transmission will not engage
15,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
JOECUETER
The vehicle transmission will not engage on drive when the weather is cold. Once the vehicle engine is warm the vehicle will operate normally.
Note: The transmission was completely rebuild four years ago with less than 20,000 on the rebuild transmission.
Please advise
Thank you
Apr 1, 2017 at 1:43 AM
  • 55,673 POSTS
Of course check the fluid level first. If okay the transmission seals may have gone bad. This is a classic seal problem becasue the seals work better when warmed up.
Please let us know what you find so it will help others.
Best, Ken
Apr 3, 2017 at 5:28 AM
