My rodeo leaks oil at one side thru the spark plugs. I have to put in a quart eveyone 750 to 1000 miles. What is the problem?
Thank you
Mar 4, 2010 at 7:56 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
2CARPRO JACK
CAR REPAIR CONTRIBUTOR
It sounds as though the gaskets for the spark plug wells are bad, allowing oil to leak in.You will need to replace the entire valve cover gasket,the kit should come with the gaskets/seals for the plug wells.
Mar 4, 2010 at 8:02 AM
ABN509
MEMBER
Is it something that I can do or will it need to go the a shop
Mar 4, 2010 at 8:04 AM
2CARPRO JACK
Looks like the 3.5 is a little more complicated than the 3.2 engine. I guess it would depend on your mechanical ability.If you feel as though you can do it,I would suggest a bunch of digital pics as you take things apart, it is easier to look at a pic so you know exactly what you took off and where it goes
Mar 4, 2010 at 8:08 AM
ABN509
MEMBER
Can you give me a ball park price if I go to a mechanic?
Thank You
Mar 4, 2010 at 9:16 AM
2CARPRO JACK
Looks like Mitchells labor guide is about 2 hours of labor and the gasket set is around $35. You are looking around $200
