1999 Isuzu Rodeo Question smoke
235,359 MILES • 4 CYL • 2WD • MANUAL
G17
My car overheated and the Cylinder head and head gasket cracked according to the repair shop and they replaced the cylinder head, head gasket, thermostat, thermostat o-ring and they replaced the serpentine drive belts. Now the vehicle smokes. They did a 109k oil kit and that did not help and they did a dynamic engine cleaner which entailed running it for an hour at 1500rpm. That did nothing as it still smokes. Any suggestions if this can be fixed?
Nov 16, 2009 at 6:17 AM
  • 31,937 POSTS
Hi there.
What engine oil are they using, don't use a synth oil use a mineral oil and for those miles 20w-50, now the main problems that with the new head, this has shown up a weakness in the lower end, a common problem that they should have explained before fitting a new head, you will need a leak down test to determine if this is the case, but i feel there is not a lot to be done except a lower end overhaul.
Mark (mhpautos)
Nov 16, 2009 at 7:06 AM
