1997 Isuzu Rodeo Question Where is the dipstick to check flu
1997 ISUZU RODEO
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHAUNLIBBY81
I cannot find the dipstick to check the fluid level on my 1997 isuzu rodeo. it seems to have a leak and just started to act funny when accelerating from stops. I wanted to be sure fluid level was accurate but cannot find dipstick....
Sep 10, 2008 at 6:07 AM
DOCFIXIT
  • 18,828 POSTS
Does not have a dip stick. On very level spot run for 3 min shifting through gears. Shut off slide under see tans pan two plugs one is higher up not the one in bottom of pan. Remove higher plug if fluid comes out it is full. Now the trick is that plug is also how you add ATF Dextron III dealer pumps it in maybe you could fashion a hose and funnel to get fluid in.
Good Luck
Sep 10, 2008 at 6:35 AM
