1988 Isuzu Pickup Too Much Oil Smoke
ISUZU
CHAZWJ
I started my 1988 pickup after having loaned it to someone and white smoke bellowed from the tail pipe. I shut the engine down and noticed oil had blown out through the exhaust header gasket where it connects to the exhaust system. I checked the oil; the level was about half way up the length of the dipstick. Have I messed something up or do I just need to drain the oil to its normal level?
Jan 27, 2006 at 7:20 AM
2CARPRO JACK
  • 11,533 POSTS
start by adjusting the level. oil will be in the exhaust for a little bit so expect more smoke at the beginning
Feb 2, 2006 at 7:30 AM
Suggested Repair
Drain the oil down to the normal level on the dipstick. Expect some smoke at first while residual oil burns out of the exhaust.
Conversation Summary
The owner of a 1988 pickup found the engine overfilled with oil after loaning it out, with white smoke from the tailpipe and oil blown out at the exhaust header gasket. The expert advised correcting the oil level and noted that oil already in the exhaust may cause smoke for a short time afterward.
