1988 Isuzu Trooper II 2nd Gear Locked
ISUZU
BLU1988
I have a 1988 Isuzu Trooper II 259000 miles with a 2.6 manual. I am able to use 1st 3rd 4th and 5th gears but unable to use the 2nd gear do i need a new clutch or is there a simple way of unlocking this gear because i hate to miss a gear your help would be very appreciative but unfortunately at this time i am unable to donate i have no money really that is why i need your help thank you for your time.
David-NJ
Jan 25, 2007 at 7:27 PM
2CARPRO JACK
  • 11,533 POSTS
Sorry but it sounds like the trans needs to come out and be repaired or rebuilt.If all other gears work then 2nd gear obviously has the problem. You really should have it fixed before any kind of debris in the trans causes more damage
Jan 25, 2007 at 11:52 PM
Suggested Repair
Remove the transmission and repair or rebuild it. Second gear is the likely failure, and it should be fixed before debris causes further damage.
Conversation Summary
The owner of a 1988 Isuzu Trooper II with a 2.6 manual transmission can use first, third, fourth, and fifth gears but cannot engage second. The expert said the transmission needs to be removed and repaired or rebuilt, and that it should be fixed before debris causes more damage.
