Clutch Master Cylinder
ISUZU
JERSEYCANE
90 Isuzu Pickup 190,000 still drives great. I was beginning to drive the vehcle, I stepped on the clutch pushed it to the floor and it didn't return until I pulled it back up manually. I checked the Master Cyl and it was empty.
Poured fluid in it but it didn't give me a clutch: I assume the MC needs to be replaced.
Does a Clutch MC need to be bled? And if so how do you do it?
As I poured fluid into the cylinder and pumped the clutch, the fluid all leaked out somewhere around the MC. The slave Cyl. was replaced 2 years ago?
Oct 3, 2006 at 3:06 AM
KERRY
My 1989 Isuzu Elf truck (mileage 98,000) has lost all clutch pressure. We have been able to fix it usually by bleeding and topping up the fluid. This does not seem to work anymore. Can you please help me with this problem?
Oct 22, 2006 at 1:51 PM
