I have a 1995 isuzu Trooper with an automatic transmission. The vehicle has about 140,000 miles on it.
Recently, I was driving the vehicle and the rear ABS warning/brake light came on. When that happens I loss the first and drive gear gear. Took it to a repair shop and he found a blown 15 amp fuse. Took the trans apart, checked and serviced it, and it worked fine, but still blows that fuse. I replace the fuse and it works for a while and then blows the fuse.
It is getting to be a pain replacing the fuse all the time and would like to know what you think is the problem.
Oct 24, 2007 at 8:03 AM
