2006 Other Isuzu Models fluid analysis
2006 ISUZU
63,000 MILES • 4 CYL • 2WD • AUTOMATIC
GORDIE01
Fluid tests were conducted on a vehicle that I am interested in. It is a medium duty Isuzu NQR with an automatic trans. Below are the results. What does this tell me?
Silicon 28 PPM
Lead 10 PPM
Tin 15 PPM
Copper 286 PPM
Aluminum 50 PPM
Silver 0 PPM
Nickel 0.5 PPM
Chromium 0.2 PPM
Iron 83 PPM
Glycol N/A
Water NEG
Fuel N/A
Feb 9, 2010 at 12:39 AM
RACEFAN966
  • 5,029 POSTS
Well which fluid does this pertain to?
Feb 9, 2010 at 1:28 AM
GORDIE01
It is the report for the transmission fluid.
Feb 9, 2010 at 2:11 AM
RACEFAN966
  • 5,029 POSTS
Ok it sounds like it is tranyfluid with a few miles on it. It has some metals in it, as the transmission and fluid gets mileage on it this is normal, this is why the fluid and filter should be changed every couple of years. The way I check fluid out is with the chart below as when trans fluid goes bad and the trany is having problems the fluid color changes. So here is the chart that I use. The numbers are in parts per million. Transmission fluid chart. what color is yours?
https://images.2carpros.com/forum/automotive_pictures/249564_transmission_fluid_types_1.jpg
Feb 10, 2010 at 1:54 AM
GORDIE01
This is a unit I am looking to purchase. If I purchase this unit would you suggest me changing the tranny fluid before I drive it 1800 miles based on the metal numbers? I can not answer your question on the look of the fluid as I am not with the vehicle.
Feb 10, 2010 at 2:15 AM
RACEFAN966
  • 5,029 POSTS
Ok when looking to buy a vehicle I suggest a compression test and check all belts and fluids for color. Do they look new or old and neglected. How does the anti freeze look and brake fluid(is it black or clean flush as needed) and engine oil and so on. I also like to check the brakes for wear and check u-joints for tightness and front end for any signs of worn parts and tires for signs of uneven wear. If you buy this truck I recommend changing engine oil, transmission fluid and fuel filter and check air filter and spark plugs. This way you will know where the maintence is. As you know vehicles are mechanical so they can break at anytime without warning too.
Feb 10, 2010 at 2:32 AM
