1993 Rodeo Hesitation when it gets warm
1993 ISUZU
RITZLIMO
  • 7 POSTS
My vehicle is a 1993 rodeo 4x4 with a 5 spped manual transmission and the v-6 engine. It has about 140,000 miles on it. It started to lose power on exceleration only when it is warm. I cannot get it to go above about 4000 rpms. When I first start it up no problems for the first 10 or so miles. If I get out of first quickly and work my way to 4 or 5th, I can get to were I am going, but maximum speed is around 50mph. It idles just fine.
I have replaced all the plugs and wires, fuel filter, Catylitic converter, and all 3 coils. No one has a unit that can read codes going back to 1993 around here, so i am at a loss. I do not want to just start changing all the emmision controls. This vehicle is fuel injected. Seems the more I drive it, the worse it gets. Shut her down and start it up later and she runs fine again till it warms up. I am going to make a donation, becaue I realy need your help. No one around here wants to mess with it, because they cannot read the codes.
Most of the things in the book under troubleshooting seem like they are fulltime problems, vacum leaks etc.
Thanks in advance for any help you can offer!
Jun 8, 2007 at 1:16 AM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Check the fuel pressure. If you can, while driving so you can see pressure at the higher rpm's.
Jun 8, 2007 at 8:17 AM
RITZLIMO
  • 7 POSTS
I disconnected the O2 censor and all it really did was run richer. It ssems to only do it under a load. When just reving the egine it revs fine. When I am driving I cannot get over 4000 rpm, but if I put the clutch in and just give it gas, it goes past 4000 with no problem.
Jun 8, 2007 at 9:33 AM
2CARPRO JACK
  • 11,533 POSTS
Id still check fuel pressure while under load (driving)
Jun 8, 2007 at 10:02 AM
