2000 Isuzu Amigo
126,000 MILES • 6 CYL • 4WD • MANUAL
PHILIP.ZACHARIAH
I have engine idling problems. The engine rmp sometimes goes up and the then comes down. This happens mostly when i switch on the AC and when i start it on the morning.
I did a tune up and it is still the same way. is there something i can do to get my idling stable
Jan 19, 2010 at 9:04 AM
LARDON
You should check your Idle Air Control Valve ( IAC ). It is set on you throtlle body,near the TPS ( Throtlle position sensor).
https://images.2carpros.com/forum/automotive_pictures/485704_1300884537648080_26_2.jpg
Feb 18, 2010 at 11:44 PM
