Issues with gear shifting (first, second and third) when driving the car.
98,000 MILES • 4.0L • V6 • RWD • MANUAL
F1SH73
Issues with gear shifting (first, second and third) when driving the car. Shifts fine if engine turned off. Changed transmission fluid, replaced clutch master cylinder, normal level of clutch fluid in the reservoir. Where to look next? Should I drop down the tranny and replace the clutch and flywheel?
Sep 7, 2016 at 9:06 AM
CJ MEDEVAC
  • 11,000 POSTS
How did you bleed the clutch system?
The Medic
Sep 7, 2016 at 9:22 AM
F1SH73
With the vacuum pump
Sep 7, 2016 at 10:21 AM
CJ MEDEVAC
  • 11,000 POSTS
This is probably the best explanation I've come across as to what's going wrong and how to correct it!
https://www.youtube.com/watch?v=s6cVYgzCU18
Return with good news!
The Medic
Sep 7, 2016 at 10:37 AM
