1998 Ford Mustang Lunge while running down the road
138,000 MILES • 6 CYL • 2WD • MANUAL
DAVID_RADKE
I bought this used car a few months back and it was running great. I had the oil changed 2000 miles ago and had them replace the manual transmission grease. A couple weeks ago it started lunging when in 2 and 3 gear. I thought it was just rough road but it keeps happening. It doesn't happen when you are accelerating or applying the break. Just seems to happen when idle running down the road. I have placed my hand on the gear shift and it seems to vibrate when this is happening. Not sure if I can duplicate for the repair shop staff. Do you think it is a clutch or transmission issue?
Sep 14, 2009 at 5:40 AM
DOCFIXIT
  • 18,828 POSTS
When they did trans was Automatic Trans fluid put in?
Sep 14, 2009 at 5:53 AM
DAVID_RADKE
three week prior to problem.
Sep 14, 2009 at 6:05 AM
DOCFIXIT
  • 18,828 POSTS
Idle good? No lunge in 1st? or 4th? only 2-3? Does Tach go up and down?give it gas and stops?
Sep 14, 2009 at 6:13 AM
