Is there a bolt or plug?
6 CYL • FWD • MANUAL
SPRH3RO
I have been losing my fluid for my clutch, but one day I was driving and my clutch stopped working, but when I put fluid in it now it just leaks all out, but there is no a hole where it seems something is missing to hold in the fluid, I'm I right?
Oct 16, 2014 at 6:25 AM
WRENCHTECH
  • 20,758 POSTS
It's going to be either a bad slave cylinder or clutch master cylinder. It needs to be inspected.
Oct 16, 2014 at 6:41 AM
SPRH3RO
But what I don't understand is that it was working fine before just had a little leak, but then it just stopped working all of the sudden I had never had a problem with it just the leak, but there is a hole where it looks like a plug or bolt should be where the fluid is coming out of. And if it is a cylinder how do you check it?
Oct 16, 2014 at 6:47 AM
