Is it the clutch or tranny?
136,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
WIZARDOF OZ
  • 7 POSTS
Sometimes when I get my car up to say 3000 rpms and shift the rpms stay the same and go crazy high when I hit the gas. If im in cruise then push the clutch in, expecting to have slow down for the guy in front of me, then let out of the clutch and hit resume cruise itll redline if I dont catch it quick enough. Ive had someone say they think its the clutch but hes not very reliable. If so what do I need to get? Ive looked up an oem exedy clutch set for $150, figured I might as well do the slave if im already there but not sure if its internal or not, i seen on some threads that the pilot bearing was needed but i looked it up at the parts store and all it showed was a universal so idk if i have that or not. Can anyone tell me what I need 100% if thats even it?
Mar 10, 2016 at 6:50 AM
HMAC300
  • 48,601 POSTS
leave in 4 th gear and hit the gas if it doesn't move right away yourclutch is probably bad
Mar 10, 2016 at 8:13 AM
WIZARDOF OZ
  • 7 POSTS
From a stand still or moving? I did it with 5th the other day before work and had it about 85% released before it started to stall
Mar 10, 2016 at 8:16 AM
HMAC300
  • 48,601 POSTS
put in 4h or 5th gear while driving and hit the gas if it slips then it'the clutch
Mar 10, 2016 at 8:27 AM
WIZARDOF OZ
  • 7 POSTS
Alright thanks ill check it tomorrow on my way to work
Mar 10, 2016 at 8:36 AM
WIZARDOF OZ
  • 7 POSTS
Alright so its weird. Not sure if this is normal or not. Last night i left and went a few miles to my other apartment and when i came back i was just revving in 2nd, 3rd, and 4th before it finally kicked in enough to get me moving. Then i stopped at a stop and heard a loud explosion and the smell of something burning and still no clutch so i parked it. Then this morning i hopped in it and you wouldn't even be able to tell there was a clutch problem. It had balls and was ready to go.
Mar 10, 2016 at 8:49 PM
HMAC300
  • 48,601 POSTS
well your clutch may be on it's last leg then or the release bearing is going to push through the pressure plate. if that happens your pedal will go to floor but clutch will still beable to move the car . but won't be able to shift. Also there are rare instances where the crankshaft thrust bearing wears out and crank shaft move to and fro to far effecting clutch operation.
Mar 10, 2016 at 11:40 PM
WIZARDOF OZ
  • 7 POSTS
Yikes. So what all do i need to replace while im in there? Im looking at an oem exedy clutch set from napa, ive heard the flywheel should be replaced, pilot bearing, not sure if thats in the set or not, i know the throw out bearing. Anything else?
Mar 11, 2016 at 10:18 AM
HMAC300
  • 48,601 POSTS
before you start replacing parts uneccessarily have a local pro take a look at this the kit shoud have a disc plate and release bearing pilot should be replaced and look for bentk/broken release arm or wornout at bearing.
Mar 11, 2016 at 10:20 PM
WIZARDOF OZ
  • 7 POSTS
I work at a shop i just dont do trannys so if i mention bring my car in i get yelled at
Mar 11, 2016 at 10:30 PM
HMAC300
  • 48,601 POSTS
oh flywheels can be resurfaced btw. then have your partner look at it see what they think
Mar 11, 2016 at 10:54 PM
WIZARDOF OZ
  • 7 POSTS
Is it trustworthy to resurface the flywheel though
Mar 12, 2016 at 12:02 PM
HMAC300
  • 48,601 POSTS
ya they don't off that much
Mar 13, 2016 at 3:07 AM
