Is it necessary to replace my clicking actuator
105,000 MILES • 4 CYL • MANUAL
ANGELLD1
The actuator is clicking in my car and I cannot afford to pay $200.00 to $500.00 to have it replaced at a shop. Turning the knob to the recirculated air kicks on the AC motor which stops the clicking, but sucks the gas (like every AC does).
Is it vital that the thing needs replaced right away or can I just deal with the annoying clicking?
Nov 16, 2016 at 2:04 AM
HMAC300
  • 48,601 POSTS
try pulling HAVC fuse inside car it may reset it remove it for sixty seconds with key on then reinstall. if not it will need to be replaced especially if it is blend door and you will have no heat.
Nov 16, 2016 at 4:18 AM
ANGELLD1
The heater and the AC both work just fine, but I will try the fuse tonight. Thanks =)
Nov 17, 2016 at 4:23 AM
HMAC300
  • 48,601 POSTS
when you pull the fuse it resets the actuator, so it may stop clicking that you are experiencing. If not the actuator is probably bad.
Nov 17, 2016 at 5:01 AM
