Intermittent not starting issue
124,000 MILES
ANN FARRER
After reaching my destination the car will not immediately start, after waiting a while it starts.
Mar 2, 2022 at 6:04 AM
  • 110,244 POSTS
If the issue happens when the engine is warm, the first thing I think of is a possible faulty crankshaft position sensor. When they start to fail, they are adversely affected by heat. When they cool off, they work again.
Do me a favor. Take a look through this link and let me know if it seems to mirror what you experienced.
Next, I need you to scan the computer to see if there are diagnostic trouble codes that may help. This vehicle has an OBD1 system and doesn't require a scan tool to check for codes. All you need is a short jumper wire or even a paper clip.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
If possible, perform the test above and let me know the results.
Mar 2, 2022 at 12:12 PM
