Intermittent loss of power/acceleration
200,000 MILES • 4 CYL
TOTALMC
  • 117 POSTS
Car drives fine most of the time , but occasionally experiencing loss of power/acceleration. will suddenly start sputtering and barely do 30 MPH (which is proving to be dangerous in traffic).
Car has new spark plugs and coils seem fine.
Injectors are all firing (verified only by the sound passing through a screwdriver).
Fuel pump has been replaced.
I'm not sure what to check next. any guidance is greatly appreciated.
Aug 30, 2021 at 10:56 AM
  • 110,251 POSTS
If it is intermittent, it could be that the catalytic converter is loose internally and moving around causing flow restrictions. By any chance, have you ever noticed a rattling sound from under the hood or under the vehicle?
Take a look through this link and let me know if you feel it mirrors what you experience.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Also, let me know if the check engine light is staying on while the engine is running.
Aug 31, 2021 at 12:43 PM
TOTALMC
  • 117 POSTS
Oh , and I forgot it's showing a misfire on #1 and #3 .. no codes for the catalytic converter, or anything else (just the 301 and 303), but I'll rattle the catalytic converter and see.
Aug 31, 2021 at 1:09 PM
  • 110,251 POSTS
Let me know what you find. Also, let me know if you feel the misfire at all times.
Aug 31, 2021 at 2:38 PM
TOTALMC
  • 117 POSTS
The car seems to run strong most of the time, but then it will just start to sputter out of nowhere (between 30 and 50 MPH), then again disappear and run fine.
Aug 31, 2021 at 2:43 PM
  • 110,251 POSTS
Based on your description, it makes me question if there is an issue with fuel pressure. When this happens, have you ever noticed smoke from the exhaust or an odd smell? Also, I noted you replaced the fuel pump. Was the regulator and fuel filter replaced? Have you checked the fuel pressure to make sure it is within the manufacturer's specs?
Let me know. Also, since we have two specific cylinders misfiring, it may be time to do a compression test. It has a lot of miles on it, and there could be an issue there.
Here are two links showing how both procedures would be done:
Let me know if that has already been tested and if you are comfortable doing them
Sep 1, 2021 at 12:13 PM
TOTALMC
  • 117 POSTS
Car seems to run fine most of the time , only occasionally does this problem arise (but definitely enough to be a problem)
Have not checked the fuel pressure (difficult with this model and do not have proper adapters to get it off the rail), fuel pump was replaced with a coffee can size unit that I believe held everything inside by smoke or odd smell from the pipe. I'm assuming you're thinking head gasket, have not noticed either.
I'll try a compression test next time, but I'm always worried the adapter will screw off the hose and then be impossible to remove from the bottom of the hole.
Thanks again.
Sep 3, 2021 at 12:42 PM
  • 110,251 POSTS
A head gasket was in my mind. However, I was wondering if the fuel mixture was rich. That would cause black or gray smoke and an odd smell. Have you ever noticed that?
Sep 3, 2021 at 2:14 PM
TOTALMC
  • 117 POSTS
No smells or smoke and I do use my nose regularly to diagnose how an engine is running (sometimes I think my nose and ears are the best diagnostic tools).
Sep 3, 2021 at 2:54 PM
  • 110,251 POSTS
I agree. Sound and smell tell a lot. If you have a chance, I would check the fuel pressure to confirm it is within spec. Also, if it is, then I would check compression.
Sep 3, 2021 at 3:16 PM
