Intermittent loss of power
2018 NISSAN NAVARA
200,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
MLUNGISI
  • 8 POSTS
I have another problem developing from another YD25 engine. When driving it's having intermittent power loss. I have replaced the prime pump, sediment sensor cleaned the fuel tank, and put a new diesel filter, still, I am having the same problem.
When driving the vehicle just loses power. the RPMs drop.
Mar 14, 2022 at 6:55 PM
If while driving and the power on a diesel engine drops out that is normally a fuel issue, so I think you are on the right path. What I would suggest is when driving the vehicle monitor the fuel pressure with a scan tool when it loses pressure. You should have fuel pressure sensors that will tell you what the commanded pressure is and what the actual pressure is. These should be close to each other at all times with the actual pressure trailing by a second or two.
Also, do we have any codes at all?
Basically, I think we need to confirm we have two things. First, we have proper flow/volume of fuel and the correct pressure.
https://www.2carpros.com/articles/symptoms-of-low-engine-power
We don't offer this engine in the USA so we don't have a manual on it, but I am sure we can work through this and figure out what the issue is.
Let us know what you find with this, and we can go from there.
Mar 15, 2022 at 8:47 PM
