My navara d40 engine stall at idle. In the morning when I start it, there is an knocking sound from the engine. After some minutes that sound stops. But engine stops at any bend or color light, when I press the clutch. One mechanic guy said there is a pressure leak at common rail or pressure pump or faulty at injector. But he is not sure about it and said it will cost more than $20k.
I have already changed fuel filter, replaced rubber hosses near fuel filter and cleaned the fuel lines. But faulty stays the same.
what is the exact reason for this? Can anyone help me on this. Thanks.
SPONSORED LINKS
Monday, February 10th, 2014 AT 10:54 AM
