ABS and tire monitor light on
97,000 MILES
ALDWIN
ABS instrument light coming on after driving a while, and check right front tire monitor.
Apr 22, 2018 at 6:03 AM
Good morning.
As far as the tire, check the air pressure to be sure it is all the same pressures.
As far as the ABS light, it indicates a fault in the system. the most common issue is a whee speed sensor. There is a code stored for the fault. A parts store can read it for you for free and then we can narrow the are of failure for you.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Apr 22, 2018 at 10:57 PM
