Did the light come on after the rear brake service? Possible that a wheel speed sensor came disconnected. The connection is on the rear of the hub, at the centerline. Otherwise, It would need scanned for codes, and that would give us some direction. I know when the rear brakes are service, the connections can be vulnerable to coming undone, or left undone if disconnected to access caliper bracket bolts to get rotors off.
SPONSORED LINKS
Thursday, June 4th, 2009 AT 11:20 PM
