Instrument cluster not working
ANGEL16
  • 14 POSTS
The dealer still thinks it’s the instrument cluster but, I sent it out to have checked and they said nothing is wrong with it. I don’t think they believe me. I told the dealer to order the part and we’ll see if it works. The dealer said I’m not responsible for the part or labor if it doesn’t work but, they want to charge for another diagnostic test. I told them that’s crap considering the code that was given didn’t fix the problem from the first diagnostic test. I’ll let you know the outcome.
Thanks,
Angel
Wednesday, February 26th, 2020 AT 12:33 PM
  • 52,797 POSTS
Good morning,
This is sounding more and more like the BCM is the issue since the signal from the vehicle speed sensor goes to it and is sent to the cluster.
Did anyone check the connector at the back of the cluster for and damaged or lose pins? That would also be a possibility.
Friday, February 28th, 2020 AT 5:11 AM
ANGEL16
  • 14 POSTS
Roy,
Not that I’m aware of. I’ll definitely mention that if the cluster doesn’t work. The dealer has ordered the part and we’ll see if they are correct or not. If they aren’t they want to charge me for another diagnostic test. I was told by the dealer the code B101E is a general code for them to start with. If it isn’t correct, they’ll need to go further and do more testing for more money. My issue is why don’t they trouble shoot. I had the cluster tested and they said nothing was wrong with it. If it’s the BCM, I can take that out and have it tested. I’m shocked that a dealer doesn’t do these things. Not only does it narrow it down and pinpoint the issue, it’s less time and money for the owner. Dealers scan check all kinds of things and separate if need be with the scan tool and the computers will tell you what’s wrong. I’ll definitely keep you posted on the outcome.
Thanks,
Angel
Friday, February 28th, 2020 AT 5:45 AM
  • 52,797 POSTS
I agree. It looks at this point that they are guessing on your dime.
You cannot remove it and test it. That is done in the car and hooked up. They have the equipment for testing but apparently not the person to do the testing or understand how to test it.
Friday, February 28th, 2020 AT 5:49 AM
ANGEL16
  • 14 POSTS
Roy,
That’s what I wanted to avoid. Are codes general or do they point right to the issue? Should they have looked further? Should they be charging for another diagnostic test if the first code was wrong and didn’t fix the issue?
Thanks,
Angel
Friday, February 28th, 2020 AT 8:25 AM
  • 52,797 POSTS
Codes are general. They point to an area of failure, not the part. There are flow charts that are generated by the code and all the steps need to be followed to determine the failure. A lot of techs do not follow the flow chart and guess based on experience.
Friday, February 28th, 2020 AT 9:17 AM
