1994 Infiniti Q45 STARTHING
TRANSGUY2010
  • 1994 INFINITI Q45
  • V8
  • FWD
  • 159,000 MILES
IT CRANKS AND TRY TO START BUT NO DICE
Friday, January 1st, 2010 AT 6:05 PM
Do below to determine if it's a fuel or spark problem:
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, January 1st, 2010 AT 9:06 PM
