2001 Infiniti I30 FUEL PROBLEM
2001 INFINITI I30
184,500 MILES • 6 CYL • 2WD • AUTOMATIC
INFINITIFRED
MY CAR SUDDENLY STOPPED RUNNING WHEN THE IDLE WAS LOW. It was like it had run out of gas, but it was 1/2 full. After 10 minutes, I was able to drive it again, but then it happened 3 times again after 15 minutes of driving. It runs fine with a high idle, but dies when it is low.
May 31, 2010 at 11:18 PM
Clean and test the IACV-AAC valve on right rear of intake manifold collector and test the throttle position sensor and clean the mass airflow sensor with an approved cleaner
May 31, 2010 at 11:27 PM
