Indicators issues
32,300 MILES • 1.6L • 4 CYL • 2WD • MANUAL
COCO7POPS
So before the problem happen, i would use the indicators like normal until recently i would hear click and nothing would work. I would then play around with my harzard button until i saw the lights flash then i would indicate like normal. Now the indicators don't work at all. However, when i lock my car the hazards flash and when i unlock my car it flashes again. Hope this makes sense.
Mar 27, 2019 at 7:32 PM
Good morning,
This sounds like the turn signal flasher is not functioning correctly.
Turn signal/hazard flasher relay is located on relay box behind left-hand side of instrument panel, next to steering column.
Mar 27, 2019 at 10:58 PM
COCO7POPS
I found the box but it does not have any description to tell me which one it is. all it has is numbers on them.
Mar 28, 2019 at 6:53 PM
They do not show a picture of the flasher but say it is at the back of the fuse, relay box at the lower left at the kick panel.
Mar 28, 2019 at 10:57 PM
