Increased emissions light
2004 BMW 525I
145,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
GBOYD0507
  • 7 POSTS
Increased emissions indication warning light?
Nov 8, 2017 at 1:23 AM
This normally means that there is a misfire or there is an issue with the exhaust system.
We need to start with checking for codes. Here is a guide that will help with this:
Once we know what codes are there, we will be able to better know what the possible causes are. However, as I stated the normal cause is a misfire so here is a guide that covers what we need to do to start with this unless there is a code pointing in a different direction.
Lastly here is a guide that covers the general info on the emission system to help explain what may be the issue:
https://www.2carpros.com/articles/how-emission-control-systems-work
Let me know what questions you have. Thanks
Dec 2, 2020 at 6:25 AM
