Ignition lock cylinder
190,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
CHRISCHANDLER913
  • 9 POSTS
Do I have to re program it after I replace the key lock cylinder?
Mar 19, 2016 at 12:50 PM
  • 55,694 POSTS
On some cars the key must be re-programmed to the car which only the dealer can do, your car is right on the line from when they started doing that so you might be okay, let me know how it goes so we can help others.
Mar 19, 2016 at 3:01 PM
CHRISCHANDLER913
  • 9 POSTS
Ok the key is a transponder key and the VIN starts with a 1. is there anyway that you know of that I can program the new keys myself?
Mar 20, 2016 at 12:05 AM
  • 31,937 POSTS
If you have a new key you will have to do a re code, if you recoded the lock to suit the original key there should not be a problem as long as the key reader is also original and matched to the key.
Mar 20, 2016 at 2:03 AM
CHRISCHANDLER913
  • 9 POSTS
No, the ignition lock cylinder that I got is a aftermarket import direct. It did not have the key code reader on it so I had to install the original one from the defective key lock cylinder onto the new one and the green key light comes on when you turn the ignition on and then it blinks and does not go off until you turn the ignition off. I have the original keys (the grey one and the black one) that originally came with the car and I have the defective key lock cylinder. The engine turns over it just does not start. After I replaced the key lock cylinder I had to input the anti-theft code in the radio and it works now also. Please help, I am just baffled on what else I can do other that call the dealership. I really do not want to do that if I don't have too.. Thanks
Mar 20, 2016 at 2:17 AM
  • 55,694 POSTS
I found this info for you, please take a look and let us know if it helps
https://www.youtube.com/watch?v=Yk5_wFMU1dM
Mar 21, 2016 at 6:09 PM
CHRISCHANDLER913
  • 9 POSTS
Ok that is a different type key the 1999 Hona Accord 4 cyl. Has a key without the key fob built into it. I have a seperate key fob for my car. The original keys to the car are 1 is grey and 1 is black ..
Apr 5, 2016 at 7:55 AM
  • 55,694 POSTS
Is the security light on or flashing when you try to start it? If not lets start at the basics, here is a link to help you with that diagnosis
Please let me know how it goes.
Apr 5, 2016 at 8:14 AM
CHRISCHANDLER913
  • 9 POSTS
Yes the security light is on and it blinks when you try to start the car.
Apr 5, 2016 at 11:18 AM
  • 55,694 POSTS
Okay that is the problem, the security light cannot be blinking, can you disconnect the battery for 2 minutes and reconnect it please, once completed close all doors then lock and unlock the drivers door. this should reset the system. If not the transponder and ignition need to be programmed at a shop or dealer please help.
Apr 6, 2016 at 2:09 AM
