Ignition key removal
120,086 MILES • 2.7L • AUTOMATIC
DAVER1
The ignition key will not go to the lock position.
Sep 20, 2018 at 4:43 AM
  • 110,248 POSTS
Take a look through this link and see if it helps. It discusses different ways to deal with a stuck key.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
If that does not help, confirm the shifter is fully in the park position. Shift back and forth a couple times to make sure. If that does not work, check the ignition fuses located in the power distribution box under the hood for a blown fuse.
Do these things first and let me know what you find.
Sep 21, 2018 at 10:56 AM
