2000 Chrysler Sebring Key Won't Turn
sounds like the steering wheel lock is on. rotate the wheel left and right while trying ot turn key
Oct 19, 2007 at 7:17 AM
I played with that for an hour with no luck. Someone else suggested rocking the car to set the shifter lock and my son is on his way to try that. Any other suggestions? Is there a transmission release to put the car in neutral without the key? Fyi This is a 2000 LXI ragtop.
Oct 19, 2007 at 7:31 AM
i dont belive so the only way i know that you could in my experience is to remove the selector rod from the tranny and put it in neutral that way.
Oct 19, 2007 at 7:34 AM
Rocking the car worked. Now I will have to have the saftey switches inspected. Thanks for the prompt reply and your help. :lol:
Oct 19, 2007 at 7:58 AM
thanks for the follow up also. now i will be able to add that to my knowledge and if someone else has the problem i can help them :D good luck
Oct 19, 2007 at 8:10 AM
Suggested Repair
Rock the vehicle to release the shifter interlock so the key can turn. Also try turning the steering wheel left and right to free the steering lock. If the car must be moved without the key, disconnect the selector rod at the transmission and place it in neutral. Have the shift safety switches inspected.
Conversation Summary
The owner of a 2000 Chrysler Sebring convertible could insert the key but could not turn it after difficulty removing it, and suspected the shifter safety lock. The expert suggested rocking the steering wheel to release the column lock and, if needed, disconnecting the transmission selector rod to shift to neutral. Rocking the car released the lock and allowed the key to turn; the owner planned to have the safety switches inspected.
