Ignition is pushed in and stuck
180,000 MILES • 3.0L • 6 CYL • 2WD • MANUAL
TURBOTAIL
  • 30 POSTS
The other day, I went to start my car, and as I put the key in, it seemed to go in a little further than usual. When I turned it over, it didn't recoil back to the normal position, so the car kept grinding like I kept the key pushed all the way forward. I had to jump out and disconnect the battery, to get it to quit. Now, to get it to start, I have to zap it with the battery. The ignition switch is stuck on. How can I fix this?
Feb 28, 2015 at 2:49 AM
  • 110,251 POSTS
It sounds like the tumbler is bad and needs replaced.
Feb 28, 2015 at 3:16 AM
TURBOTAIL
  • 30 POSTS
I'll give it a try-thanks!
Feb 28, 2015 at 3:33 AM
