ignition switch
ESMITH42554
key will not turn off the car it turn back but the car keeps running.the key is now stuck in the ignition so what do i have to do to fix it ?do you have a diagram that i can look at.or a step by step instructions to follow?
May 7, 2013 at 3:27 AM
JDL
  • 16,098 POSTS
Is the tranny in park? Can you shift it?
May 7, 2013 at 3:37 AM
ESMITH42554
year the car is in park and it will shift
May 7, 2013 at 3:55 AM
JDL
  • 16,098 POSTS
Will the key turn to the lock position? You can kill it by killing spark or fuel. Also, you could kill it by taking negative battery cable loose. I would prefer to kill the engine by spark or fuel.
If there is a problem with the lock cylinder or ignition switch, I can't fix it from here.
May 7, 2013 at 4:10 AM
