1995 Mercury Sable Ignition will turn backwards but not shu
1995 MERCURY SABLE
200,000 MILES • 6 CYL • FWD • AUTOMATIC
ALBUSFUGIT
The ignition will turn all the way back with out turning any of the ass/engine off. Also will leave the starter ingaged when it is restarted.
Oct 10, 2008 at 3:32 PM
2CARPRO JACK
  • 11,533 POSTS
There is an ignition switch under the dash mounted on top of the steering column. Sounds like yours is falling apart.Once you get to it and remove it, be sure the rod up to the key tumbler is moving properly as well
Oct 11, 2008 at 1:52 AM
ALBUSFUGIT
Thank you for the respone to my email.I am going to go out ant see if i can replace it..If I have more questions may I contact you again? Once again thank you.
Oct 15, 2008 at 3:30 AM
2CARPRO JACK
  • 11,533 POSTS
Absolutely, reply through thef orum like you did and it will notify me
Oct 15, 2008 at 3:36 AM
