Ignition coil
224,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BENJAMIN BOUTWELL
The cable that supplies power to the ignition coil plug is broken. Is there a cable that I could jump from the power supply to the ignition coil?
Aug 23, 2020 at 12:31 PM
  • 110,248 POSTS
Each cylinder has its own coil. The power to them goes through the power-train control module. You don't want to run power to it at all time and certainly don't try to power the PCM.
The only thing I can think of is to try and repair the connector or see if you can get a used connector from a salvage yard and splice it in properly. If you contact a dealer, I'm not even sure if they will be able to provide just one. It is part of a wiring harness.
Aug 23, 2020 at 1:36 PM
