Intermittent long cranking and no start issue
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
IMNOTTE42
On occasion my vehicle will crank continuously but fail to kick over and start. Later it will start with no problem. I had the fuel pump replaced but this still continues.
Sep 8, 2020 at 12:51 AM
Good morning,
When it does not start, did you hear the fuel pump run?
When it did not start, did the tachometer move up a little while cranking? That will tell me if the crank sensor is sending a signal to the ECM.
Sep 8, 2020 at 1:22 AM
IMNOTTE42
Sorry, I don't know what a fuel pump sounds like and I didn't notice the tachometer moving up. I will check if it happens again soon.
Sep 8, 2020 at 2:11 AM
Okay, keep us updated.
Sep 8, 2020 at 2:12 AM
