Engine only cranked once, will not start
256,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
SAMGREW
  • 59 POSTS
Went to crank the car. Started to turn over maybe one revolution and stopped. Now it does nothing, no click or anything.
Jul 4, 2022 at 9:47 AM
  • 55,721 POSTS
It sounds like the battery is bad or you have a bad connection at the battery, to be sure these guides can help us fix it:
and
Jul 5, 2022 at 9:49 AM
SAMGREW
  • 59 POSTS
With headlights on, I attempted to crank. The headlights did not dim at all and starter did nothing.
Jul 5, 2022 at 10:07 AM
  • 55,721 POSTS
Okay, this is telling us the starter system is not working, try shifting the car into neutral to see if that makes a difference, if not, let's take a test light and hold it on the trigger wire of the starter and have a helper crank the engine over to see if it lights up. This guide can help you see what to do. I also have included the instructions on how to replace the starter.
Jul 6, 2022 at 5:36 AM
SAMGREW
  • 59 POSTS
The wire between Bendix and starter motor was burned in two. Replaced starter. Thanks
Jul 16, 2022 at 1:09 PM
  • 55,721 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Jul 17, 2022 at 4:08 AM
