Idles really rough an stalls
2005 DODGE MAGNUM
150,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
RAS ANTDAWG
Idles rough like a stumble then stalls. Had a open circuit code on #3 cylinder. I checked the olhmes on the injectors #3 was bad. I replaced it. Started it up an still does the same thing. But i get no codes an no check engine light. Did something similar before an ended up being the egr valve. Do you think this could be the problem again?
Mar 26, 2017 at 6:31 AM
CATAFINA
  • 98 POSTS
Inspect and test your EGR valve
Mar 26, 2017 at 7:45 AM
HMAC300
  • 48,601 POSTS
it could be but also a vacuum leak or low fuel pressure will do it as well, so check all three see link
Mar 26, 2017 at 9:23 AM
RAS ANTDAWG
I changed the egr also. Stays on now though. But idles at a stumble like it wants to shut off. An at times idles really rough an shakey.
Mar 27, 2017 at 12:35 AM
HMAC300
  • 48,601 POSTS
so have you checked what has been suggested? check for a vacuum leak as well.
Mar 27, 2017 at 12:50 AM
RAS ANTDAWG
Its in the shop. Ill keep you posted on the outcome. Thanks for the suggestions.
Mar 27, 2017 at 10:24 AM
RAS ANTDAWG
So. I removed everything to expose the cams an timing chain. Facing the front of the car on the left side cam gears the chain was broke. Along with the guide an tensioner. Think its best to replace with a timing kit ir just change the broken one. Ill upload some photos.
Mar 29, 2017 at 6:36 PM
HMAC300
  • 48,601 POSTS
if your chain broke this engine will bend valves so check for bent valves by pulling heads off otherwise you'll just have to do it again after replacing chain
Mar 29, 2017 at 10:45 PM
