Idle problems
140,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
DAVID RAYMOND HOLLAND
Drives fine but will not idle.
Jul 31, 2017 at 11:10 AM
  • 55,710 POSTS
The first thing I would do is check for vacuum leaks around the intake manifold. Here is a guide that will help you get that done.
and
https://www.2carpros.com/articles/stall-at-idle
Please run some tests and get back to us we are interested to see what it is.
Cheers, Ken
Aug 2, 2017 at 7:50 AM
MAURICIO CORLETO
  • 7 POSTS
97 nissan pick 4x4 up 2.4 idling problem... i replaced the timing chain... and stared right up.. now i do not know why it would not idle, i tried to adjust the air mix screw and tps and no luck...
Aug 2, 2017 at 7:50 AM (Merged)
MAURICIO CORLETO
  • 7 POSTS
thanks any way... i am gonna try tomorrow again an let you know !!!!
