Engine does not idle, shuts off when I release the accelerator
2006 NISSAN HARDBODY
300,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
HOFISI
MEMBER
1 POST
Engine start but does not idle every time you release the accelerator it just switch off.
Sep 6, 2018 at 10:43 PM
✓Experienced Mechanic
This sounds like you have a vacuum leak or the throttle bore is dirty, but we should run the codes as well. Here are three guides to help us get started:
