Will not stay running
186,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
JOSHUA TRIVETT
Car starts and idles but pull out and shuts off.
Jan 6, 2021 at 11:10 AM
So the car shuts off as soon as you put it in gear? Or will it stay running until you give it gas and let the clutch out?
https://www.2carpros.com/articles/engine-stalls
However, if it stalls as soon as you put it in gear or even start to let the clutch out, then I suspect the clutch is failing and not fully disengaging? So when you put it in gear it pulls the engine down and stalls it. Does it jump a little or jerk at all as it is stalling or does it stall out like it is running out of fuel?
Here is a guide that helps with this as well:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Let's start with this info and go from there. Thanks
Jan 7, 2021 at 7:51 AM
